Fixed: Help me debug my DS-1 mod. Audio probbed and found where signal ends
Started by theblueark, February 23, 2006, 12:15:13 PM
theblueark
Edit: This has been fixed. I spent a couple of hours on it and found that the metal pot casing for the distortion was grounding against the metal enclosure. Pics and sound report will be up soon  ;D
Hi i've modded my DS-1 with three 5-way rotary switches. Two of them to choose between the following clipping diodes:
1. Ge
2. Si
3. LED
4. Tube
5. Lift
and the 3rd to choose the smoothing c10 cap value.
Plugged in and tested and it doesn't seem to be working. So I used an audio probe to locate the problem. Right now I'm stuck at the output of the second opamp in the BA782N. Here's what I've traced from my pcb:
I have a soft sound coming from pin 3, and a loud sound coming from pin 1, 2 and 5.
However, there is no sound coming from pin 6 and 7. Is my IC dead?
I've been referring to this schemetic, but it features the TA7136. I'll just put it here if it helps:
http://www.godiksennet.com/images/sch/DS1PG2.jpg
I'm so close to finishing this! Can't wait to try out all the different combinations of diodes. Argh! Help!  :-\
theblueark
I just measured the voltage readings at the pins.
It's 4.3V at pins 1, 2 and 5
and 0.9V at pin 3
pin 6 and 7 is at 0V.
I did not touch any of the circuitry other than D4, D5 and C10. No idea what the problem is.
O
Quote from: theblueark on February 23, 2006, 12:15:13 PM
cool! I got a mint TS9 RI from ebay a few months back with the same problem. When I contacted the seller he said that it just didn't work. It had one of the pots shorting out against the enclosure like your pedal did. Best $20 I ever spent! :D
jeroen_verbeeck
I'm verry interested in the sound samples because I'm modding my DS-2, or should I say fine-tune ?
This can give me an idea of how differend diodes sound in a pedal like this.
