adding octave up to rangemaster?
Started by birt, February 23, 2006, 06:28:30 PM
birt
is there a way i can add an octave switch to a rangemaster? some kind of mod? or just add a green ringer or something in the same enclosure?
http://www.last.fm/user/birt/
Processaurus
You'd need a seperate circuit for that, the Green Ringer is good, and can be made on a fairly small piece of perfboard.
Once in a while it IS possible to simply change this and that, add a part here or there, and you can turn pedal type A into pedal type B.  Perfect case in point is the phaser-to-univibe conversion.  The Rangemaster, however, is not one of those.  What a person would have to add WOULD amount to the entire component set of a second pedal.
So make the second pedal!
Wild Zebra
  I was jamming that setup the other night.  It sounds awesome!!  I have a green ringer onboard my gittar so whenever I want it.  Octave up\flip of the switch.
"your stripes are killer bro"
Eirik
Last night I read a thread i this forum that mentioned using the "octave part" of the RM octavia after a Fuzz Face. I might work with the Rangemaster as well?
On the other hand, the green ringer is an easy build so it's probably worth it  :)
Eirik
