DOD FX 60 wiring help!?!
Started by WorkBench, February 25, 2006, 10:10:04 AM
WorkBench
I found this old DOD FX 60 stereo chorus pedal.  all of the wires a unhooked inside, and the switch is gone.  I put in a carling with 6 legs for a switch.  I cant' figure out how to wire it up.  I do not own a digital camera, or I would post pictures.  Any references, or ideas?  Thanks!
Chris
All good things in all good time
WorkBench
shanter
before
not before
i sort of cleaned up the LED wiring myself cause the quality of it was driving me nuts. the dark green wire coming from the board is orinally light purple.
1. is your switch a drop-in carling?
2. where did u get it from!
the stock one its a piece of poop, no solder terminal, almost impossible to solder to it.
-shant
WorkBench
Man, I appreciate your help so much!!! I just got it working based on your photos!  Sounds nice.  I found the original switch and am using that for now.  I have a carling with 6 lugs, tried it, but I had to hit the switch twice to turn it on and off????  I would like to use a true bypass switch, so may order up from Smallbear.  Again, thanks very much!!!
Chris
WorkBench
Shant,
another thing-What is the value of the resistor that is hidden begin the yellow cao at the bottom left hand corner of the board.  you see there is a cap in front of the chip, then up from that a cap blocking the resistor.  I can tell that the one in my pedal is not the original value.  Could you let me know?  Thanks!
Chris
shanter
it looks like its 47k. i didnt  open up my pedal again but im looking at a picture and the bands look like. yellow, violet and orange so im pretty sure its 47k.
-shant
ps. do you get any hum when u turn on yours?
WorkBench
Thanks again Shant!  Mine really only gives me a good amount of hiss, but nothing that would be noticable in my band situation.
Chris
