black (stamped?) circuits
Started by choklitlove, March 01, 2006, 04:52:57 AM
choklitlove
here's what i'm talking about:
it's on top of other circuits.  it looks like it might be stamped.  it is conductive (i metered it), but i don't know what material it is.
i guess what i want to know is: can it be soldered?  i would try, but i don't want to ruin it.
thanks!
my band.                    my DIY page.                    my solo music.
Nasse
Looks like some conductive stuff, there must have been some rubbery buttons on that that have similar conductive surface. I think they use this kind of stuff with remote controllers and many other products.
I have seen a repair paint for remote control contacts on some catalogs, silly expensive if I remember. Dunno if they use same stuff on these rubber buttons, quess not...
Maybe you could replace it with mechanical switches (add resistors in series if needed)
choklitlove
yeah, it's a keyboard.  it had a rubber strip with button that connect the traces.  do you know if it's solderable?
MartyMart
If it is rubber based ( conductive ) then you'll just burn it up !
You'd have to use the same stuff to "attach" anything to it ... is my guess :D
MM.
choklitlove
the rubber is separate from the 'buttons' that connect the traces:
it has to be the same material.  what is it?  and is it solderable?
Nasse
I typed "rubber keypad repair" into search engine, lots of hits
This was interesting http://www.trackdown.co.uk/faqs.htm
I think if some tracks are broken you can fix it with conductive pant but for contacts you need something else
gez
If the buttons no longer work, you need a new rubber pad.  Get in contact with the manufacturer.  I had to do this a number of years ago with an old Roland drum machine.  They had the pads and they didn't cost that much.  Everything worked out fine.
gez
Having said that, the buttons pushed down onto 'raw' metal, not that black stuff...
Ge_Whiz
No, it's not solderable. It's a carbon-based film deposited onto metallic connection points.
gez
Perhaps you could touch it up with conductive paint?
Peter Snowberg
If you can find a break, you can often patch it with the conductive paint used to repair rear-window defogger elements.
Eschew paradigm obfuscation
choklitlove
i don't need to repair anything.  i need to connect wires to it.  thanks, Ge_Whiz.  i think you're the only one that answered what i asked...
