Preliminary GEO Tube Wah Layout For Your Perusal
Started by Paul Marossy, March 16, 2006, 03:22:45 PM
Paul Marossy
Anyone want to offer opinions? Pros & Cons?
Click Here
I realize that there are safety issues that must be addressed, that is a given. I'm looking more for potential problems with noise, etc.  :icon_cool:
EDIT: Power supply would be in a seperate enclosure.
tommy.genes
Well I can see one problem right off the bat.
You can't see the tube from outside the pedal.
Isn't that why people build tube gear?  ;)
-- T. G. --
"A man works hard all week to keep his pants off all weekend." - Captain Eugene Harold "Armor Abs" Krabs
Paul Marossy
QuoteWell I can see one problem right off the bat.
Hmm... that's a hard one. On a wah, all you really see is the foot paddle!  :icon_lol:
twabelljr
    You can drill "cooling" holes in that section of the treadle and in the enclosure. Or maybe a plexiglass window? Definately gotta see it and make it glow bright. It'll be magic!
ps. Paul, you are a stompbox superhero! :icon_cool:
Shine On !!!
Paul Marossy
This darn external power supply just makes things so bulky. Oh well. I guess what I'll do is make something on a 1/4" plywood platform. It's going to end up being a s big as one of those Morley wah pedals! Eek!
Paul - did you think of using another "stompbox" with no knobs and no switches, just a stompish looking box to hold the power supply?
It's a relatively human-acceptable method.
Paul Marossy
Quote from: R.G. on March 17, 2006, 07:46:50 AM
Yes! I seem to keep gravitating towards that idea. I am just trying to think of a way to make it a self-contained unit (of sorts), but I don't think it is really possible. I was also thinking of an externally mounted transformer, but I have a feeling it will give me headaches with induced hum via the inductor.  :icon_sad:
Satch12879
The "big bulky" power supply is a non issue if you use the small toroidal transformer like the one used for the tube pedal at Hoffman Amps; 40mm square by 18mm high.
But a big +1 on using a second enclosure.  But why not just stick all the guts in a second enclosure and using the pedal just as a controller? Then you'll have all the space you need.
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
Paul Marossy
QuoteBut why not just stick all the guts in a second enclosure and using the pedal just as a controller? Then you'll have all the space you need.
Yeah, that would be the easiest thing to do, huh? Just a stereo cord to connect the two together. Hmm....  :icon_idea:
Paul Marossy
OK, the more that I think about it, the more sense it makes to use the wah shell only for an expression pedal and placing the rest in a seperate enclosure. The challenge there would be avoiding hum with the inductor being so close to the transformer, but I think a toriodal transformer and possibly a little bit of shielding would do the trick.
Back to the drawing board... or should I say CAD screen?!  :icon_lol:
