Corrral Choral Rin? (CE-2 Boss Chorus at Tonepad)
Started by TryingToDo613, March 30, 2006, 12:04:29 PM
TryingToDo613
Hi guys. I see this just goes to ground which in an amp is usually a meg resistor, but because it's not on the parts listing I figured I'd ask. Anyone know what it is and why it's vague? -ph
Alex C
I'd like to help you, but I don't know what you're talking about.  :)
I don't know what "Corrral Choral" is (or "Corral Choral" or "Coral" for that matter).  Can you tell us what this is, and perhaps what schematic you're using?
TryingToDo613
Sorry, it's the CE-2 pedal at tonepad. I put a 1meg across the input jack and it doesn't seem to have any effect on the fact that the thing doesn't work. Can't find a mistake in it at all but will trace it out tomorrow. -ph
Alex C
The resistor in question is a pulldown resistor, which provides a path to ground for the input cap, in order to reduce (hopefully eliminate) popping when switching.
It's labeled as "R" because a range of values will suffice.  1M is typical, and 2.2M or even 4.7M can work as well.  A search for "pulldown resistors" or "pulldown" should give you lots more info about this topic.
Quote from: TryingToDo613
In the words of R.G:
Quote from: R.G.The signal lugs on the box are not tied to the effect circuit when a pedal is bypassed. The whole point of pulldown resistors is to pull the input/output capacitors to ground when the effect is bypassed, and they can't do that if they're permanently mounted on the in/out jacks. They have to be permanently attached from the outside cap of the effect circuit input and output to ground to be effective.
This thread also has a good long post by Mark Hammer.
So, your 1M should be fine, and should not determine whether the pedal works or not.  I would look elsewhere for the problem (with an audio probe, if you haven't already).
Good luck, sir.
TryingToDo613
Thanks Alex. That's the plan tomorrow. I have a little amp I made into a probe. Thanks for the answer from RG too. I have a mind like a spagetti strainer. I suspected it wouldn't nix the build with it not there. And I never did bypass it. Haven't even put it in a box yet. Cant' get myself to work on this anymore today. -ph
