what can i safly feed my amp?
Started by miconar, March 29, 2006, 03:06:04 PM
miconar
edit: real soory, this was suppose to in begginers project if someone could delete this... :icon_redface:
d95err
I'm not expert on impedances and such, but since a typical (tube) amp has an input impedance of about 1M, I guess that a 1M resistor would work for the simulation.
I'm sure that anything you can generate using a 9V battery will be safe for your amp. As long as you have an output cap, there won't be any DC bias. As for signal level, it depends a lot on the impedance of the signal. A 10V high impedance signal is probably safe for an amp (though there will be a lot of distortion), but a 10V low impedance (speaker) signal could probably burn it.
(imagine the difference of being hit by a football going 30mph and being hit by a freight train going 30mph)
miconar
right, thanks alot for you help, and soory about all the postings, I was posting this at begginers forum im sure, but it kept poping up in here...
  Moderation...and just 'knowing
  You might be able to damage your amp, all it takes in certain circumstances is a small touch more of 'whatever like treble to blow a speaker or...
  Generally over-inputting like this results in unwanted-ness coming out of the amp, and usually the amp owner stops and turns it down quickly...not all amp users do this though.
