Clean opamp boost...whats a good one?
Started by rockgardenlove, April 06, 2006, 10:16:28 PM
rockgardenlove
I have some LF351N opamps here, and I'd like to build a nice, high volume, boost.  Any suggestions for a circuit?
Ashurbanipal
I built Anderton's EPFM treble booster, wired a 1M pot in parallel to the input to let bass through when turning the pot, and added a resistor and wired it to run off of one battery instead of bipolar like Anderton's does. By the time I got done it didn't look much like Anderton's. I prefered a tl071. The lf351 should work fine in such a circuit. Sorry I don't have a schematic because I messed around with it so much. I haven't seen a project fully like this, but maybe someone else has. This is a pretty standard simple opamp pre-amp type circuit that you might could find somewhere not listed as a guitar effect. Maybe someone else knows.
markm
MXR micro amp comes to mind for me.
Although, in the laouts section of this site there are a few other boosts that use IC's.
They all look like interesting builds.
   MM
