More Distortion on my From-Scratch TS-808/9/10/X
Started by Deathmagus, May 26, 2006, 12:24:41 AM
Deathmagus
Well...  For my first project, I decided to build a TS-808, based on the schematic from General Guitar Gadgets.  I hooked up with a friend of mine who's into electronics, and went at it.  Before building, however, I also looked at the TS-9 and 10.  Since they are (it would seem) very similar to each other (merely a resistor or two off from each other) I also added in the attributes from those pedals as well, so I can switch between all the models.  This is the Schematic I designed:
Switch 1abc is the thru-pass/LED toggle, and switches 2/3 add the resistors necessary to make it a T9 or T10.  The other switch is simply an on/off switch.  If the switch for T-9 is off, and T-10 is on, I get a previously unused setting, which I call T-X.
The only differences between what I have built and what I designed are (I believe) that the chip isn't actually the JRC (which is being shipped in a week or so), one of the caps (.22 uF?)is actually a little stronger than it should be (but the rating difference is less than 5%, so it's within tolerance range of the "correct" resistor), and I parallelled 3 smaller capaciters to match a cap I didn't have.  The second two changes I think are negligible.
My problem is the level of distortion.  Currently, at maximum drive, level, and tone, I get a very crisp, clean, overdriven tube amp sound.  It sounds quite lovely, actually, but I've heard sound bytes of modded 808s that pack a much harder punch.  My question is what might I have done to have screwed it up.  Am I supposed to be able to get a stronger drive out of just the pedal alone?  Is it all in the JRC op-amp?  How can I get a wider range of sound from my box?
Additionally, I can't notice any difference between the 4 combinations of switch settings (from switches 2 and 3).   I can understand this, since they're all Tubescreamers, but is there a good way to get a little more variety from the different settings, while remaining true to the Tubescreamer sound?
Any suggestions would be appreciated, and I would be happy to answer any questions.
rockgardenlove
No clue, but Transmogrifox has a mod that you might want to try...see if that helps.
http://stompboxmods.com/modslist.php?id_pedals=33
markm
Deathmagus
The diodes I'm currently using are IN194B's - Does that help?
Also, since I'm not sure that my schematic came through, the one I made can be found at
http://ic1.deviantart.com/fs9/i/2006/145/5/c/ShadowScreamer_Schematic_by_Deathmagus.png
Deathmagus
Well, I started fiddling around with it, wiring 2 diodes each instead of one, and when I changed it back, it seemed a lot "crunchier" might have just been a loose connection.
Thanks to all for help!
bancika
Try Kelley mod (it's described on his site), it will increase gain range - less gain wit pot turned down and more gain with pot up.
twabelljr
Shine On !!!
AL
GEO FX "Technology of the Tube Screamer" EVERYTHING you could possibly want to know except why a "vintage" TS-808 costs more than a guitar.
AL
