MXR Phase 100: toggle switch for depth?
Started by Bucksears, May 13, 2006, 09:07:52 AM
Bucksears
I've been going around in circles on this, but......
I've given up trying to come up with a variable depth control for the MXR Phase 100 at GGG's site. I'm going to settle for a toggle switch to break/engage the connection on the board. I would connect the switch to the two pads where the blue and green wires are attached to the two pads on the GGG board from the rotary switch. I'll use separate controls for speed, regen and 'manual.'
Can I just use either a flip toggle ala the Small Stone phaser or to go further a DPDT footswitch for the connection and add an LED?
Thanks again,
- Buck
nelson
Looking at the schematic couldn't you just wire a pot as a voltage divider leading to the LED's in the Vactrols?
My project site
Winner of Mar 2009 FX-X
soundcollage
Look for posts by Mark Hammer, as he is the phaser guru. I built a phase 100 with 5 knobs and 4 switches using his sugestions and it's amazing.
james
