I wanna learn...... and build this pedal!
Started by Bernardduur, June 23, 2006, 08:20:22 AM
Bernardduur
Hello all!
So I wanna build the fuzz only of the Acoustic 360 amp (here's a schematic I made from it. I've noticed that it runs on 25V (I guess because the amp ran on this voltage). Is it possible to bring the voltage down to 9V and run the fuzz on this? What items should be replaced and in which way?
As my title said I wanna learn why and how.......
Am learning something new every day here
SquareLight | MySpace account
Gus
look at a fuzzrite circuit, look at the circuit in this thread
http://www.diystompboxes.com/smfforum/index.php?topic=46232.0
look for the current threads that have other circuits like this in them and add a EF at the output.
Bernardduur
Wow.... it is the same pedal...... I've seen a lot of them but never noticed the resemblance; great!
btw, what is an EF?
EF = Envelope follower or envelope-controlled filter....usually.
Bernardduur
Hmmm, there is no filter in this pedal..... its just a fuzz
RDV
#6
Gus probably means Emitter Follower which is like a buffer that you see at the end of a lot of circuits(including the one you've drawn).
HTH
RDV
Bernardduur
zjokka
I guess you already saw jc's site; he built it with 3 9Vs so it seems from the picture.
http://www.lynx.bc.ca/~jc/pedals360.html
I also wondered about what voltages are 'required', but I guess I will be building a controllable voltage supple soon.
RG responded to a similar question of mine with regard to the rhodes preamp here
ZJ
Bernardduur
Yep; been there, done that.....
I already have a multi-PSU (9, 12, 15, 18, 24 and 25 volts, both + as -) and am doing some experiments,  but I have no "experience" with these things.
For example, when I measure the power on the collector of the transistor (on for example 25V) can I regulate the resistors on the collector side so I get the same voltage on 9V? Or is this complete weird thinking?
