pot installation (stupid question)
Started by stratblues, May 30, 2006, 06:09:09 PM
stratblues
I'm building my first pedal and I'm getting ready to drill a hole for the Pot. There is a small 'nub' that sticks up on the side of the pot. I notice on the Electro-Harmonix pedals they have drilled a small hole for the 'nub' to stick through. After looking at other pedal on here and elsewhere they do not. Should I cut it off? not worry about it? or just drill a seperate hole for it?  Thanx. ???
comfortably_numb
Usually I just take some pliers and snap that little nub right off.  That seems to be the consensus here I think.
The nub is just there for anti-spin, so you could use it if you want, or you could just get a lock washer to go on the underside of the enclosure.
In any case, either drill a hole for it or break it off.  If you leave it on, it will keep the pot from sitting flush against the enclosure.
Ciao,
CJD
delbowski
hi and welcome to the forum!
yeah i either snap the tab off with a pliers or file it off and use a lock washer... works great for me and is real easy to do.
del
rockgardenlove
I just snap it off :)
If you want to you can drill a second hole though.
KORGULL
I snap it off too. It is surprisingly easy to break. I only drill the extra hole for those tabs on toggle switch washers.
