Blend without volume loss
Started by Bernardduur, June 04, 2006, 12:57:40 PM
Bernardduur
Hi all!!
I build the Splitter blend and the Seans B. Blender and I notice a volume loss when I put the blend pot at 50% with a regain of volume when it is turned to one side.
Is there a way to  keep the volume constant?
Am learning something new every day here
SquareLight | MySpace account
Have you looked at "Panning for fun" at GEO? It's an implementation of a constant-power panner.
Bernardduur
Wow...... that works great! Thanks R.G.
Harry
Where you using a normal dual-gang pot? If so you can use a panning pot instead (each gang has only half of it's side resisting). http://www.stewmac.com/shop/Electronics,_pickups/Potentiometers_and_push-pull_pots/4/Potentiometers_and_Push-Pull_Pots.html
Bernardduur
Nope, just a normal pot and it works great!
DiyFreaque
RG, you rock on so many levels.  Thanks for this!!!!!
Cheers,
Scott
