Adding bottom end to Dist+
Started by BN, June 08, 2006, 02:01:59 PM
BN
I built a Dist+ a while ago, using the GGG schematic. But I don't like it, it's much to "squeaky" in my opinion so I wonder if you guys have any suggestions on what to do to add a little (or a lot...) bottom to it?
I did include the optional capacitor C5 in order to avoid oscillation, but I don't think I used any of the other "optionals".
"Rock 'n roll keeps you young, but you can only get away with that for so long. Eventually you become too old to stay young. And I think that's the point I reached" - David St. Hubbins
Seljer
I think C4 would be what you want to change if you wanted to add more bass (in the same way if you were doing this to a tubescreamer: http://www.muzique.com/lab/fatt.htm )
The stock cap value results in full bass at minimum gain/distortion setting, and loses bass as the gain is increased, finally resulting in a 6db/octave rolloff starting around 720hz at full gain.  A .22uf value shold probably get you what you want.
BN
Thanks! I'll try it as soon as I can
WGTP
Another suggestion, try adding a .047uf cap between the diodes and ground.  You may need to go as high as .22uf or low as .01uf, but you can adjust the bass content.  This will clean up the bass a little bit since less will be clipping, but the highs will be unchanged.  It should also increase the output.  Balance it with the other cap changes and let us know what you think.   :icon_cool:
Stomping Out Sparks & Flames
gez
I second WGTP, great mod for diode clippers that limit bass as gain increases...
wampcat1
Here's a mod to try on the dist +.
brian
BN
I did replace C4 with a 0.22uF and it sounds much better, but the Dist+ is never going to be my favourite distortion device...
I didn't try any of the other mods on this one, mostly because I'm lazy  :-[
But maybe I'll do it some other time
Thanks for the tips!
analogmike
Quote from: wampcat1 on June 09, 2006, 12:19:09 PM
standard passive tone control is a good idea on the dist+.
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
WGTP
The circuit in the diagrahm with the 10K pot is a pretty cool way to do it.  I have been experimenting with that and by 1/2 or x2 the cap or resister, you can get a preset without using a pot, or switch resistors/caps.
Since the Dist + is reported to have low output, the 100K volume mod would probably be needed since this reduces output.   :icon_cool:
