where can I purchase spdt switches ?
Started by donald stringer, July 23, 2006, 06:55:10 PM
donald stringer
At a reasonable price, smallbear only has spdt momentary.
troublerat
The Tone God
So you need SPDT toggle footswitches ? Both Digikey and Mouser carry Carling switches of that type.
Andrew
jonathan perez
any
Why not use a DPDT? They cost the same... just wire up one half and leave the other half unused (or use it to add a led indicator)
It's supposed to sound that way.
I second that.  Equally important as price, SPDTs will not take up any less chassis space.  Although some of those older Carling SPDT switches, while they may not occupy more space in terms of square inches, have a long and slender profile/footprint, rather than square.  I can see where that might be useful in some instances.  If it is the square footprint you want, though, I don't think there is much difference.  I also don't thing that any SPDT could have a smaller footprint than the DPDT Alpha switches that Small Bear sells (http://www.smallbearelec.com/Detail.bok?no=23).
MartyMart
Maplin "Ultra Miniature Toggle switch SPDT" code : FH98G
dimentions : 7.5mm x 4mm ( internal of box footprint )
Top including washer 1cm round  !  fits in a 5mm drilled hole
MM.
