Joe Davisson's Vulcan (really compact) perf layout
Started by Xavier, August 02, 2006, 05:46:14 PM
Xavier
I will follow Marty's advice and build the Vulcan. I have a few 1950b-type boxes, and that's the reason why I like compact and *congested* designs :icon_mrgreen:.
Another one for you fellas. Again, if you see any weirdo let me know and I'll correct it.
MartyMart
That's tight !!
BTW, as I said, I much preferred the Jfet version !!  :icon_wink:
MM
cab42
Quote from: MartyMart on August 02, 2006, 07:34:32 PM
That's tight !!
MM
You can use the same layout for the jfet version. I used Martys BJT vero layout with Jfets. Only a few components are of different value.
However, watch the pinouts of the transistors, you might have to twist them some.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
