Tonebender delay problem
Started by drewl, November 19, 2007, 09:46:13 AM
drewl
Hey all, I just built a Tonebender MKII fuzz which sounds great. The only problem is there is a dealy in the signal when it's turned on.
Is this common or did I do something stupid?
The delay is at the first transistor, signal is on the base when swithced on, but the output at the collector takes a millisecond to be amplified....leaky FET?
Thanks.
frankclarke
Do you mean a delay when you hit each note? On Q1 a 1 meg resistor base to -9V might help for Ge. Maybe FETs don't work well in this circuit.
drewl
#2
To clarify, when you first switch the fuzz on there's a delay in the sound until the first transistor turns on.
They are supposed to germaniums in these fuzz'z.
I don't know why I siad "FET" duh! there's no FETS in the darn circuit! not awake yet!
This is the 3 gremanium PNP transistor fuzz.......
drewl
Looks like the 1M did the trick.
Have no idea if it changed the sound since I'm at work and can just view the response on a scope with a signal applied.
Thanks.
