Yun's 5k trimmer trick , useing only one trimmer
Started by JasonG, August 23, 2006, 04:52:59 PM
JasonG
Hey guys still working on that big muff. Thanks again for all the links haveing thoes cap numbers helped alot.
   I am modding a big muff Yun recomended useing a 5k pot insted of the emitter resister. I am only useing one where would be the most effective place for it ? Thanks again!
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
Yun
the 5K trimmers should go from transistor's emmiter to ground.
BUT:  It'll sound WAY better to jumper Q-1 through Q3 's emmiter STRAIGHT to ground.  THEN, put the 5K trimmer from emmiter to ground on Q4 (the transistor after the tone control) .  Why?  This will "boost" the tone control to give you a better versatile tone control.
On one of my BMP's; after doing the "emmiter to ground" trick, you simply couldn't hear the tone control at all- so, after putting the 5K trimmer in there, adjust until you get the proper versatility.
Then; you simply jam and enjoy  ;D
"It's Better to live a lie, and forget the past, then to Forget a lie, and live the past"
