alpha pots
Started by scaesic, August 30, 2006, 01:23:29 PM
scaesic
how come the 16mm alpha pots don't have solder tags on them?
are they designed only for pcb mounting?
markm
They usually do although, they do make a PCB mount version as well.
scaesic
actually it was just banzai, they have the solder tag ones in the "guitar pots" catagory, instead of "alpha pots". They;'re also over twice the price!
Mihkel
Don't the 16mm full shaft pots have solder tags and the split shaft ones the solder pins?
markm
Quote from: scaesic on August 30, 2006, 01:50:29 PM
:icon_rolleyes:
scaesic
whats the point of full shaft ones?
Noplasticrobots
Full shaft pots let you mount more pots in a limited space by mounting some further back in an enclosure while some are mounted flush to the enclosure. Sort of like a zig zag.
I love the smell of solder in the morning.
scaesic
i see. I thought the main difference was you couldnt grip knobs as well.
