Belden Cable 8412 ?
Started by Arn C., September 01, 2006, 12:51:07 PM
Arn C.
Howdy All,
       I have some Belden 8412 wire (2 conductor shielded microphone wire)  20 AWG(.52 sq mm).   I was wondering if I should use one of the wires  and clip the other off or use both wires soldered together for use as a guitar cable?
       I know impedance is important as well as the length of the cable being used.   I think I will make 10-15 footers if this helps.
Here are some specs:
ELECTRICAL CHARACTERISTICS :
Nom. Characteristic Impedance: 52 Ω
Nom. Inductance: .18 µH/ft
Nom. Capacitance Conductor to Conductor @ 1 KHz: 30 pF/ft
Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz: 55 pF/ft
Nom. Conductor DC Resistance @ 20 Deg. C: 10.2 Ω/1000 ft
Nominal Outer Shield DC Resistance @ 20 Deg. C: 3.06 Ω/1000 ft
Max. Operating Voltage - Non-UL: 600 V RMS
Max. Recommended Current: 4 Amps per conductor @ 25°C
Arn C.
MartyMart
2 core and a shield ?
Sounds like you could use it for gtr and "ground" one end of the shield for even less noise :D
IE: Shielded as you would use in an amp or stompbox for less noise.
MM.
Arn C.
Thanks Marty for the info on your idea!
Peace!
Arn C.
lumpymusic
Quote from: Arn C. on September 01, 2006, 12:51:07 PM
... Belden 8412 wire (2 conductor shielded microphone wire)  20 AWG(.52 sq mm).
That conductor to other cond & shield capacitance is
pretty high. I would expect some high freq loss.
I've done it and seen exactly that. A built in HF rolloff
filter. Works fine as a jazz cable with a 175 with traditional
jazz tone. Might not be what you want for rock.
Lumpy
Did you do a lot of those Emergency Broadcast Warnings?
Yes. Had it been an actual emergency, I would have had told you.
www.lumpyvoice.net
In Your Ears for 40 Years
www.lumpymusic.com
lovekraft0
Quote from: lumpymusic on September 02, 2006, 04:45:29 AMThat conductor to other cond & shield capacitance is
8412 was designed for balanced 600 ohm use, where the capacitance isn't as much of an issue. There are definitely better choices available, but you could do a lot worse.
George Giblet
I agree with lumpymusic that capable capacitance is on the high side - but it's not toooo bad either.
For example compare it to the Canare L-2T2S at 33pF/ft, the Belden is 1.7 times higher so it can only go 1/1.7 the length.
Since you have the cable you might as well use it.
See,
http://www.diystompboxes.com/smfforum/index.php?topic=39439.0
For your cable with 55pF/ft,
220pF: 4ft
470pF: 8.5ft
1nF:    18ft
So 10ft is good but 15ft is getting on the high side.  Two 10ft in series using a True-Bypass effect will go over 1nF.
