Transistor
Started by dist, September 08, 2006, 04:40:37 PM
dist
Hi. Found some old schematics (70's) on an fuzz box. Thought id give it a go as it was simple, and probaby sounds... weirdo.. he he.. But anyway. It calls for 2 bc 170 (npn) witch by coincidence i have lying around and someting called meo 412...  Annyone know an equivalent for this? Its an transistor, pnp, but that is all i know.
Any help would be appreciated.. Thanks
captntasty
A quick search out there revealed that it is probably a ME0412  with a zero not o..  which is a silicon PNP.  I didn't search too much but a search using this nomenclature with "datasheet" or "data sheet" should turn up some specs - enough to figure out what would work in its' place.
It is no measure of health to be well adjusted to a profoundly sick society. - Jiddu Krishnamurti
RLBJR65
Richard Boop
dist
Thanks allot..  I'm building one right now. Found that i had some souting pnps lying around
