12ax7 in the boss MT-2 CLipping section. Sounds great!, want more clippage
Started by MadSkillzMan, September 08, 2006, 01:18:13 AM
MadSkillzMan
hey guys. Ive been lurkin and tinkerin for some time now thanks to the info on here. I managed to cram a 12ax7 inside my MT-2 tonight, and it does sound pretty sweet! theres like NO NOISE, but its got that tight tubey sound.
But i am used to this pedal being heavier (and colder and solid state sounding lol) and i was wondering if there was a way i could boost the signal coming to the clipping section (the tube is behaving as a clipping pair). Id rather not just add a diode in to give it more of a crunch, id rather the tube do most of the work, since im digging the sound OK
Any info is greatly appreciated, thanks in advance!
trevize
birt
i guess the stage before the tube is opamp? maybe use a parallel opamp for more "clean" power so you just overdrive the tube more?
http://www.last.fm/user/birt/
343 Salty Beans
Quote from: birt on September 08, 2006, 05:18:37 AM
He's right. You can piggyback two opamps and get a lot more clean power.
MadSkillzMan
Im going to have to try that then, i thought the op amp is what did most of the distortion?
These op amps are all inline, so im going to have some fun playing with that.
