Schematic / Hookup Request
Started by cat, October 16, 2006, 11:41:03 AM
cat
Hey guys,
I am after a schematic and hookup diagram for a true bypass strip. I have checked out the singlecoil.com article but I am still a little confused about how to hook all the 3PDT's together and to the 9V supply etc.
If anyone could provide me with a schematic or with directions to where I could find one I would very much appreciate it.
Thanks guys,
Cat
tcobretti
I'm not sure I understand what you're asking.
Are you saying you want a series of true bypass loops?  Are you asking how to make the power supply?
cat
Ok well I want to make one of these: so that I can hook up pedals up to it on the new pedal board Im making.
I have this schematic for the switches
I want to know how to hook say 12 of these up together and how to hook up the input and output jacks etc.
Cat
Austin73
Cat,
can u not do it like this http://www.musikding.de/product_info.php?cPath=52&products_id=380 click for bigger pic.
When u look at drawing its quite simple to add more loops by just missing out the jacks and connecting to next switch.
hope that helps
Aus
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
cat
Thanks Austin, Thats more like what Im after. I was just having trouble figuring out how to hook the 3pdt's together and then to the jacks.
Cat
Austin73
no worries, let me know how you get on as I might fancy having a crack at that one day
Aus
Austin73
cat,
just noticed on the pic you have of the single 3pdt switch I think (not sure as I'm tired! lol) that its not correct surely the resistor should be on the +9v side of the led not ground! If you use the link I sent u , you might need to add resistors to each switch and led as when I used the single one to both led's they faded!
Hope that makes sense.
Aus
