tytewadd pcb trace layout?
Started by flibbergibbin, March 16, 2006, 07:26:43 PM
flibbergibbin
Does anyone have a tytewadd layout on pcb? I tried going off of Dragonfly's vero layout or strip board layout as well as the schematic on Circuit Snippets page but I can't get it to work. Anyway, I thought if I had a pcb tracing layout it wouldn't be a problem. Tired of debugging. Thanks in advance.
coffyrock
I could use a hand with this circuit as well. I've got the stripboard layout and circuit snippets schematic, and followed them exactly, but I cannot get it to work. I did substitute the J201 (which I couldn't find) for a MPF102, but I'm not sure if that is a problem because I read you could do that and still get it to work pretty well.
After it's breadboarded, all I get is a very minimal audio signal. It works like regular when bypassed with the DPDT. I'm not sure how to measure the voltages or what to learn from the measurements as I'm very new at this... I am guessing it's the pinouts of the MPF 102 or 5088, but I'm sure they are correct as I've cross referenced them both with the DIY faq.
Has anyone built this circuit who could give me a hand, pleez? :icon_confused:
maybe there is a PCB or perf layout I'm missing? (seems like I've searched everywhere!)
Built so far: ROG Ruby, matching pair of LPB2s, Mr. Clean, Easy Drive,
Next up: Bazz Fuss, ROG Grace Overdrive, Smashdrive.
