Return Of The Wild Mouse
Started by smallbearelec, October 21, 2006, 01:58:26 PM
smallbearelec
Sounds a bit like a bad horror movie, right? The need for redesign of this one was, please excuse the bad pun, gnawing at me for a long time. But it is done, and well worth the wait. Check out the sound clips.
http://www.smallbearelec.com/Projects/WMouse/WMouse.html
SD
Wimpy
I´ll bet some cats will love it, play with it many times. For certain songs you need this kind of secret weapon to dial the tone in the pocket, can´t do without.
erix
Cool Steve!
I still have a PCB from you of the original Wild Mouse that I've never built.
Is it possible to build the revised circuit on that board - seems like it would be....
ok,
erix
smallbearelec
Quote from: erix on October 21, 2006, 04:03:48 PM
Cool Steve!
You would have to hack the thing up too much. If you return the board to me with a copy of this msj, I will post store credit to your account for the value. I forget what I was charging, but I will try to look it up.
I hope you will go back and do one...it's a really versatile and unusual device.
SD
Dan N
Are you stocking that switch? I love the size! A 3P4T would kill for Big Cheese clones!
smallbearelec
Quote from: Dan N on October 21, 2006, 06:18:56 PM
The switch in the WM is 1P6T. Mouser has the other models in the series up to 2P5T. I do offer a standard-size Lorlin switch, my SKU #0226, that would be right for the Big Cheese.
RickL
One small nit to pick: in the second paragraph of suggestions and notes you refer to R12 needing to be 100 Meg. It looks like a typo - should be R21.
Have you tried building it with a regular wah inductor like a Fasel? When I built my Bow Wow Yoy Yoy I used RS transformers for the inductors and was never satisfied with the sound. It came alive when I used Dunlop replacement inductors. I'm not suggesting it doesn't sound good the way it is but would an inductor change make any audible difference?
smallbearelec
Quote from: RickL on October 22, 2006, 02:01:02 AM
Have you tried building it with a regular wah inductor like a Fasel?...Would an inductor change make any audible difference?
Thanks for picking up the error! As far as I can hear, different inductors do make a small audible diff, but it is not night and day.
