Rebote Build report
Started by oldrocker, October 21, 2006, 08:04:51 PM
oldrocker
I finished the circuit board and I'm only getting a clean signal.  The pots don't do anything at all.  I'm a little worried that I might have fried my PT2399 IC.   When I first put power to it I found 9 volts was going to pin 1.  I found a disconnected ground and when I fixed that I got the 5 volts.  Does anyone know if this would hurt the echo chip?
oldschoolanalog
The "absolute maximum rating" for V+ according to the manfacturers datasheet is 6.5 V.
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
oldrocker
Well I didn't end up frying it.  Thank goodness.  I was able to get it working.  It sounds great and this will be a lot of fun to play around with.  My only problem is I already ordered two more echo chips which I don't need now. :icon_sad:  Oh well at least it works.  I think it sounds good with my single coils and a little gritty with my humbuckers but that's no big deal.  Tonepad comes through again with a great schematic.
geertjacobs
If you have 2 more PT2399's, you could try to build the PT-80 and compare it side-by side with the Rebote...
alfafalfa
Geert ,
Did you build both ? And if so what are your findings ?
The Rebote 2.5 is next on my list !
Alfafalfa
Gila_Crisis
for opamps and transistor i never solder them directly on the board but i use sockets. so when i put them in i'm sure they are in the right position and if you must change them, it's a lot easier as well, don't need to desolder the whole thing!
markm
I gotta hand it to you oldrocker, that's a hell of a perfboard build!
Congratulations!  8)
geertjacobs
QuoteGeert ,
No, but I'm really curious so that's why I'm suggesting it.   ;D
oldrocker
Well I'll have to look into the PT-80 and see if I have the parts on hand.  Does anyone know about the charge pump and if it the PT-80 works on 9 volts?   I have guest coming in to stay with me next week so I won't be pedal building until they leave.  Thanks Markm.  Well you're right.  It was challenging perfing it but it was well worth it.  I avoided building it for a while because I wasn't too sure I could do it without ordering a PCB for it.  I've gotten pretty good at perfing now and so I'm more apt to try and take on a more difficult build.  Although when it didn't work right away I got nervous having to debug it but thank heavens for the audio probe.  Man that's a life saver.  Thanks for the congrats.  And again thanks to zpyder for a layout that made it easier to accomplish.
oldrocker
Quote from: Gila_Crisis on October 22, 2006, 08:35:42 AM
I almost always use sockets too.  Very rarely do i not use one.  I did socket the PT2399 and the TL072.  I even socketed the 78l05 too just because I was waiting for it to get shipped to me and I wanted to have the board built so could just plug it all in.  It all worked out in the end.
boogietube
The charge pump worksin the pt-80. 9v in 17 -17.5 v out.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
Oh yeah - If you don't have the compander for the pt-80- I have several collecting dust. E-mail me.
Sean
