Printing on PCBs
Started by modsquad, November 17, 2006, 12:19:22 PM
modsquad
Okay so how do you get the cool component layout printed on the PCB after etching?  I would like to look more professional. :icon_smile:
"Chuck Norris sleeps with a night light, not because he is afraid of the dark but because the dark is afraid of him"
Pushtone
I read another forumite just used more PnP.
He ironed on a PnP transfer of a GGG WIRING layout onto the component side. Not the trace layout.
So size it in a graphics program. add text if necessary and mirror the image.
Print onto the PnP and iron on the opposite side as the traces.
Gilles C
I never tried it "yet" but a t-shirt tranfer paper would also do the job I think.
http://www.misterinkjet.com/tshirt-transfers.htm
You could cut the paper in some smaller photo size formats so that you don't need to use the whole sheet of paper at the same time.
Gilles
modsquad
I can see the PnP, but I noticed that most of the lettering is white.  Wouldn't using the PnP make it black as in the toner?
Stan
Seljer
Yep, its black, its pretty easy to see over those regular browny yellow PCB blanks. I've noticed that black component layouts were common on older (20+ years) PCBs too.
but thats the best you can do without going and doing actual screen printing like the big PCB manufacturers do to get white text and whatever other color...
Paul Perry (Frostwave)
If you use PnP, it isn't black, it's blue! (not sure how permanent the blue layer is though).
