Rebote 2.5 delay sounds great , but the distortion is a pity , suggestions ?
Started by alfafalfa, November 11, 2006, 10:21:34 AM
alfafalfa
 Mark,
That's strange indeed, the noise however disappears when I shorten the delaytime !!
What caps did you use for the picofarad range instead of ceramics ?
Alf
markm
rogeryu_ph
Alf,
Hi, This one is only suggestion: Try replace 0.082uf all three. Parallel the two cap 0.068uf (683K) + 0.022uf (223K) to make = 0.09uf. If your tiresome to do this just use 0.1(104K) to all three. By the way I already solved my Rebote Popping switch. The culprit is the FET 2n5484 on the millenium. I replaced it with 2n5458 its magic the pop disappear...  I'm going to recommend it to the forum to help other who's dilemma is the same.
alfafalfa
Hi there rogeryu_ph
Why do you suggest replacing the 0.082 caps ,what's the reason ?
Alf
rogeryu_ph
Alf.
It so happen mine is :icon_biggrin: I never suggested it to you before. Only the 7805 TO-220 type that I used and the 20k trimmer isn't it. It so happen 0.082uf is not available anywhere here that is why I opted to use two caps parellel value with 0.068uf + 0.022uf but has a value of 0.09uf isn't it. I use three of these. Maybe I'll borrow a diigital camera so you could see how crowded my pcb is.. :icon_lol: I think this maybe the magic you know.."Capacitance" maybe giving it little more the sound may not be distorted no more.... Well it's up to you as I said.  About the MXR noisegate I'll share with you my new Boss NS2 on that forum :icon_razz: Thanks.
