signal cap question?
Started by waldo041, November 28, 2006, 09:43:42 AM
waldo041
http://www.unclespot.com/sigcap.html
does this apply to stompbox circuits also or is it just something to be mindful of in tube amps?
thanks guys.
peace,
waldo
Meanderthal
 Well i'll be damned! If that's really true, I can't imagine how it would NOT apply! Now I gotta wonder about a few builds that worked, but just didn't "sound right"...
MartyMart
That article wasn't from April 1st was it ??  :icon_wink:
Meanderthal
QuoteIn the case of some types of capacitors, such as ceramic disks, multi-layer ceramics, or silver micas, there is no "outside foil", because the capacitor is made of a single-layer, or stacked layers of dielectric material and conductor.  The orientation of these capacitors makes no difference.  Also, some higher-voltage film caps (typically the 1000VDC/450VAC and higher values, such as the Orange Drop 716P high-voltage units) use a "series-wound" technique that has two separate sections, side by side, with a common "floating" connection layer, usually at the bottom of the layer stack.  These caps will have no inherent shielding either.
Form this link: http://www.aikenamps.com/OutsideFoil.htm
Could that be the reason that some folks advocate ceramic caps? Dammit, I don't have a scope, so I guess I'm screwed. (provided this is factual, and applies to low voltage applications)
