R.G. Easy Vibe R.G. Easy Vibe Schematic?????
Started by axeman010, November 26, 2006, 12:32:29 PM
axeman010
Right, before I go and create this and re-invite the wheel, does any body please have a Schematic for the Easy Vibe
which has the parts labelled as per R.G.'s easy vibe PCB layout?
Many thanks
Axeman
Hanging on in quiet desperation is the english way
Harry
axeman010
Hi
I have the schematic from here, but I am trying to debug a Vibe built on R.G.'s layout and its no so easy
when you cant match the non-labelled schematic parts to the labelled PCB parts.
Axeman.
Torchy
#3
Found this kicking around ...
axeman010
Thanks very much Torchy .......... you are a star !!!!
should make my debug a walk in the park !!!!!!!!!!
Axeman
analog kid
SEARCH
  yes that's a real nice little operational schem I referenced to it when I built my first E.Vibe way back when, you should be pretty close if your voltages come close to those in the schem , assuming no problems in the audio path that you've yet to remedy.  Search function when needing help with resources AND Audio Probe when troubleshooting your way the through the circuit!  Never fails(me) and you learn alot
should've put in a thanks to the artist of the paritcular oper.schem but i can't recall whom it was who gave that to me?
See the man with the stage fright, just standing up there to give it all his might..
axeman010
Thanks to all who helped on this one.
Now have a wonderful Vibe sound, no background noise - just magic.
Got to do a paint job on the box. I installed it in an old Schaler volume pedal, will post pics and clips when finished.
Gonna call it the "Box of Sighs"
Axeman.
