Easy Vibe Oscillator Question
Started by GibsonGM, December 29, 2006, 02:28:40 AM
GibsonGM
I built an EV using the original hand-drawn Hollis schem with TL064's...it worked well, but clicked and nothing would get rid of it, so I re-built the oscillator section on a separate PCB, to be mounted away from the filter sections.  Just tested it, and it is oscillating  :D
I am wondering, out of the 3 OA's used for it, what controls the Rate (beyond the 100K rate pot...).   Mine doesn't want to go faster than about 1 Hz.   Could the pot be backwards??  Used a wah pot, log.  Or is there another component in there responsible for the rate?  I tied the unused portion of the TL064 to Vbias, -input to output.
Thanks  8)
The Tone God
At my site under the downloads area there is a schematic of the LFO with a bunch of mods I made. You can give them a shot. Its been awhile since I played with though.
Andrew
GibsonGM
Thanks, T.G., I'll look at maybe modding it after I can get it running right.   It seems to be doing its thing, is flashing an LED, but the rate doesn't go over about 1 Hz.  I've built this before, just not off-board, so probably did something wrong!   Reversing the pot doesn't help.   I used 22uf instead of 10uf to ground on the schem for added 'click insurance';  in simulation it doesn't change the rate.  Can't figure this one out...
