Troubleshooting Nurse Quacky
Started by greenacarina, December 10, 2006, 06:40:54 PM
I don't know if this could be the problem but the way the layout is drawn could be confusing.
The connection from attack 2&3 should go to the same row as range 1, on the layout it could look like it goes to the row above with a jumper to the row below. If you wired it up like this it would drop the bias voltage to 2 volts or so and stop the envelope follower working.
Here's how it should be wired up
greenacarina
Quote from: slacker on January 01, 2007, 02:34:05 PM
You are correct! I have both of those traces wired together as that's how the layout seemed to show it. I'll fix it and see what happens!!  ;D
Thanks.
Chris
