Ibanez DE7 Delay/echo Schematics
Started by Psych0F0x, January 03, 2007, 05:35:28 PM
Psych0F0x
I was wondering if there's a schematic out there for this pedal, and whether it's buildable? Is it good?
The Tone God
The function is your friend.
Search criteria used: de7
http://www.diystompboxes.com/smfforum/index.php?topic=47686.0
Build-able ? Yes but it depends on your skills.
Good ? Depends on your taste.
Andrew
finkfloyd
I have one of these, I like the echo setting, I use it to try to achieve 70's floyd style tape delay and it works very well, and has a long 2 second + max delay time if desired too,  its a very affordable pedal too.
Very good pedal if you like floyd
if I had the money i would grab a boss dd-20, a little pricy though.
Psych0F0x
Thanks, normally the search function is my friend, but I guess I didn't search well enough..
Ooh tough schematic, I think I will pass. A bit above my level..  :s
Dirk_Hendrik
Other than that, the main controller chip is (out of the back of my mind) an Altera programmable device. Little use without having it run the embedded software programmed on the chip.
More stuff, less fear, less  hassle and less censoring? How 'bout it??. To discuss what YOU want to discuss instead of what others decide for you. It's possible...
But not at diystompboxes.com...... regrettably
