Little problem with a ds1
Started by Nashtir, September 28, 2007, 02:30:09 PM
Nashtir
Hi guys, my ds1 fell to the ground and 3 wires desoldered from the pcb and jacks, they are the brown one from the pad "1" on the pcb, the yellow wire and the white wire. I know the white goes to the output tip, but the yellow and brown?I can't find any schematic indicating this! thanks in advance
Melanhead
Brown is the input "tip" and yellow is the input "sleeve" ... Assuming you have the black plastic input jack, yellow is the one that is straight across from the grey ground wire ..., brown is on the side ...
Nashtir
Melanhead
Glad I could help .. I have a dead one on my bench that has been there for about a year so I just took a peak inside ;) ... i suppose I should fix it someday too!  :icon_mrgreen:
