Multimeter Suggestions
Started by ThisBrian, February 08, 2007, 04:42:23 AM
ThisBrian
I need a new one, but don't want to get another cheapo/freebie one. Needs to do all the good stuff, capacitance etc. Thanks  :icon_mrgreen:
Noplasticrobots
I'm sure if you don't want cheap, Fluke should have something for you.
I love the smell of solder in the morning.
ubersam
I was looking at some Fluke DMMs to replace my dying unknown-brand DMM. They definitely not cheap, a little too "not cheap" for my pocket. After taking into consideration what I actually needed (as opposed to what I wanted). I also read a bunch of spec sheets and compared features between all the DMMs I considered. After all that, I ended up ordering an Extech EX420. Spec. sheet wise, it seems like it will do for me.
brett
Here's my main DMM (I got it on sale for US$16):
http://www.jaycar.com.au/productView.asp?ID=QM1535&CATID=&keywords=multimeter&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=The specs are about right for pedals and amps (probably don't need duty cycle).
The thing that this DMM doesn't have is a transistoor tester.  I use a very cheap separate DMM for this (US$7).
Unless you're very serious, you don't need:
RMS volts
Fluke brand
Fancy leads
Temperature probe
Duty cycle
Brett Robinson
boyersdad
Very nice meter. Would be nice to have all that with transistor tester too.
What exactly do the transistor functions provide anyway? Never had a meter that had one (and up until around December I mainly used an analog meter anway :))
I like amps etc.
JonFrum
I couldn't afford a Fluke, so I bought a Craftsman at Sears. It reads all resistances about 2-5% low. Penny wise...
Next time I'll get a Fluke.
GibsonGM
I've got an Extech I'm pretty happy with.  It does have temp probe, which I use for various things not related to DIY, so that's cool.  Capactitance, diode, frequency.  Was about $45...not a bad company, IMO.
zarathustra
#7
I've been using a Mastech, like this one. I snagged mine on eBay for ~$20. They seem to pop up there pretty often for about that same price. It's definitely a budget meter, but it does all the important stuff (including diodes and transistors), and I haven't had any problems with it yet (knock on wood).
Ronsonic
If it works, it's a Fluke.
Haunt the pawnshops - occasional good deals on Flukes to be had there. I've got a 27 I paid about $30 at a pawnshop and an 8050 that cost $40 on ebay. You won't beat that.
I've got my Flukes for workhorse multimetering. I've got two old radio shack things that have a really good transistor checker and a seperate LCR meter for caps and coils.
Really easier and cheaper for me to pick them up seperately along the way.
Ron
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
markm
My "freebie" from Circuit Specialists is great......so far.  :icon_cool:
