mxr+ trebly.
Started by Rafa, February 14, 2007, 04:23:27 PM
Rafa
My mxr+ is extremely treblyis  this ok? It seems to be working ok, no noise or lack of sustain.
Her is a very short sound clip I recorded
http://www.geocities.com/rafa23189/mxrt.mp3
Thankssss
Cheers
Rafa
  Hard to tell from the short clip, sounds like more than a DIST+'s distortion to me...more like a digital setting called 'under the steel plate' or something.
  What do the voltages say. Dist+ doesn't/shouldn't cut a whole lot of bass, I found having an adjustable rolloff instead of a fixed cap across the diodes to be useful for adjusting the treble content.
John Lyons
So is this a MXR Distortion+ ?
Try adding some capacitance to the output. Was .001, try .002 or .004 or more.
As pete mentioned, you can add a tone control with a cap to ground and a 100K pot to have a variable low pass filter to shave off some high end.
Basic Audio Pedals
www.basicaudio.net/
Rafa
the tone control should fix the problem
Thankssss a lot
GibsonGM
Wow, that sounds really rough, man!  Nothing like a Dist+ should sound.  I'd follow the advice of the above, after first assuring yourself that it's assembled correctly (proper bias voltage and everything).
Meanderthal
 There is a .047uf cap that goes between the gain pot and ground. It rolls off bottom end as you turn up the gain.  Increase the value of this cap for more bottom end.
Ditto.
That cap rolls off bottom starting around 720hz at max gain.  Use a .15 - .22uf cap instead and you'll get more meat to the sound at max gain.  Stick a 22-33pf cap in the feedback loop (in parallel with 1M resistor) of the op-amp to limit high end, and use a .0022 - .0033uf cap in parallel with the diodes to further tame fizz and piercingness.
Yun
here's how i built mine, guys:
Good sound/tone in it's simplisity
Although, i changed the output cap with a .0039uf.
"It's Better to live a lie, and forget the past, then to Forget a lie, and live the past"
