Dynacomp or Ross?
Started by Rafa, February 15, 2007, 07:56:25 PM
Rafa
Well I have everything ready to build either Ross or Dynacomp Compressors,(they can be built usng the same Pcb). But which should I built? Whats different between them?
Cheers
Rafa
Meanderthal
 The Dynacomp is brighter, clearer, the Ross warmer, smoother.
Processaurus
This has come up once or twice before.  Basically, one will make you sound like Jimi Hendrix, and one like Jimmy Hoffa.   :icon_wink:
http://www.diystompboxes.com/smfforum/index.php?topic=53792.0
96ecss
Most Country players I know prefer the Dynacomp. Most Rock players I know prefer the Ross.
Hope this helps.
Dave
  Note where the Dyna hasn't the HF rolloff components, where the Ross does.
  You can choose to eliminate or partially eliminate, or adjust the values of these components.
  I believe these components are all located near the output.
Papa_lazerous
Ross comp definately the Ross comp, I bread boarded the circuit and tried both but I prefer the Ross comp for sure
oh yeah did I say the Ross comp?
markm
Here's a vote for the DynaComp!
