How to make simple opamp gain stage?
Started by bancika, March 11, 2007, 09:35:26 AM
bancika
Can someone help me make simple opamp gain stage with TL072 using bipolar +-15V supply
I need it to recover gain in amp FX loop
Tnx
Seljer
http://en.wikipedia.org/wiki/Operational_amplifier_applications#Non-inverting_amplifier
connect the VCC+ to +15V, VCC- to -15
not sure on how neccesary are coupling capacitors
set the R1 and R2 ratio to whatever you need for the gain (or use a pot for one of them to get it adjustable)
bancika
bancika
Dragonfly
Quote from: bancika on March 11, 2007, 12:06:55 PM
what does cap in opamp loop do?
many circuits use a small (<200pF) cap to "tame" some of the high end a bit.
AC
Ge_Whiz
Quote from: Dragonfly on March 11, 2007, 12:10:08 PM
In particular, to prevent unwanted oscillation and / or RF pickup.
