Tremulus lune LDR control
Started by ThomasDJ, February 27, 2007, 05:22:13 AM
ThomasDJ
hi
I have finished building the tremulus lune and woww this thing sounds great! :) ..but now I want to be able to control the speed via LDR as a kind of progression. The 2 speed pots 10k and 1k will be the master settings and the LDR shall tune the speed when light is falling on it..  I almost figure out how (I think :s) ..but i need a little help:)
I run the speed circuit trough an NPN transistor (one side to the collector and the other side to the emitter) ..and the LDR to the base:)
This works ok..but it chance the way the tremolo sounds:s
What can I do??
best regards
Thomas:)
Seljer
http://www.commonsound.com/kits/doku.php?id=commonsound:tremulus
"Aux LFO (to modulate main)" is what you want (I think a: tremolo that goes from changes the speed up and down by itself?)
ThomasDJ
maybe it is what I want :icon_confused: I'll give it a try :)
thanks
You can probably just put the LDR across the outside lugs of the speed pot.
Seljer
ah wait, I read your first post entirely wrong.
then just wire another pot (5k to 10k I'd say) as a variable resistor in series with the current speed potentiometers (as a kind of "LDR depth" control), wire the LDR in parallel with the new pot
what slacker said would also work but it doesn't offer a way to turn it off/adjust how much of an effect it has on the speed
yeah that's a much better way of doing it.
