tube OD vs "regular" OD
Started by hendriko, June 14, 2007, 01:35:45 AM
hendriko
so, is there any real connection between those two circuit types? like, does the tube just replace one (or a few) components out of the "regular" TS style OD? or is it a complete different circuit?
any examples (schems or something with differences) would be appreciated
cheers
Gimme gimme shock treatment.
aron
It is usually a completely different circuit but it is possible to design something with the tube replacing part of a solid state circuit like you said. If you wanted to compare really simply look here:
http://www.diystompboxes.com/pedals/tubedummy.html
hendriko
cool, thanks for the quick reply aron!
so, what the link's suggesting is that a triode tube works similar to a transistor? so could i just go and replace transistors in a TS circuit with tubes?
aron
Yes you could, but that would be ridiculous since the transistors in the TS don't do enough to warrant doing this.
hendriko
haha alright..would be fun though   :P
thanks for the info!
