Multi effects board power wiring help
Started by msurdin, April 07, 2007, 08:34:30 AM
msurdin
Hi,
I am currently building a Cornish style board like a lot of people on the forum. I am having some trouble with wiring some things up for power. I am going to use one of the 9v power supplies from GGG to power most of my pedals. The problem i am having is I am going to be using 2 BK Butler Tube Drivers and I want to wire it so I only have 1 main power coard coming out of my unit. How can I wire the 2 tube drivers and my 9v power supply up so it will only have to be 1 power cable.
Thanks very much
Matt
bent
my best advise would be to build the Spyder power supply found at http://www.geofex.com/
with the transfo that can be found at http://www.smallbearelec.com/Detail.bok?no=597
i've build it and it's great ....you can supply up to 9 pedal...with a cost around 25-30 $
bent
Long live the music.....
msurdin
I am pretty new to powering stuff so I was wondering if someone could help me a bit. I have researched the 9v supply for all my 9v pedals but my concern is really powering the 2 bk butler tube drivers into my setup. The big thing is only having 1 power cord coming out of the multi effects unit.
Thanks guys!
Matt
