flatline comp...
Started by blanik, May 07, 2007, 02:09:40 AM
blanik
i'm just bored with my Tpad Ross Comp, it messes too much my sound and i want something more transparent... i'm looking into the Flatline, i heard a lot of good things about it (MarkM?  ;) )
i found Mark's PCB and bcreekmur Vero, since i'm doing only one for me i'll do it on Vero but i noticed a difference with Mark's layout, the 100uF cap between the diodes series is only a 0.1uF ceramic on Mark's layout... what difference does that cap makes? (is it related to the use of a LED/LDR assembly as opposed to a VTL5CX?) (by the way, witch VTL5C (2-3?) is better for this project?
question about the Vero layout: it's got a LED on the top right side of the board that seems to be always on? what is this for?? (does it light according to compression?)
bcreekmur's layout:
http://i6.photobucket.com/albums/y220/bcreekmur/flatlinecompressorvero.gif
Mark's layout:
http://aronnelson.com/gallery/album76/Flatline_Compressor_Condensed_LAYOUT?full=1
sorry for the question onslaught ( i searched!... with the search button.... read them all!!..lol)
MartyMart
The vero works perfectly - made one !
The top right is an indicator LED - wire it up to a 3PDT switch as normal.
MM
cab42
I also used the vero for my build, works great.
I made my own LDR/LED combo, using a couple of tips from Marty:
http://www.diystompboxes.com/smfforum/index.php?topic=45716.msg335102#msg335102
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
markm
I think I made a boo-boo on my interpretation of the schem......
It looked like an "nF" to me but in reality it's a uF. Oops!  :icon_redface:
I built mine like this and seemed to work fine to me.  ???
blanik
Quote from: markm on May 08, 2007, 12:30:43 PM
maybe that's why you were raving about the Flatline? you might have made it better!  :D
i'll try both to see if tit makes a difference...
markm
Quote from: blanik on May 08, 2007, 12:33:21 PM
One can only hope but, I'm usually not that lucky.
Most of the time my mistakes aren't very good!  :icon_lol:
