Red Fuzz Vero Layout - Could you help me verify ??
Started by solarplexus, April 16, 2007, 10:55:25 AM
solarplexus
Hi,
I just made a Red Fuzz vero layout... I never could find one and it's a great circuit... Would anyone be willing to help me verify it ?
It's not very small and could be alot better... but it's my first layout so... here it is :
Thanks for any help you can provide !
Matt
DIY Poser.
ezanker
Good job solarplexus.
Here's what I see:
1.  You need a trace cut under C1, otherwise it is shorted.
2. D1 and D2 need to connect to pin 6 (only R3 connects to the intensity pot)
3. C7 needs to move down one rail and connect to R7, not the jfet gate.
4. You need a trace cut between the wires for Tone lug 1 and tone lug 2, otherwise this pot is shorted.
EZ
solarplexus
Here's a corrected version :
Is this one ok ??
Any other errors ??
DIY Poser.
ezanker
Looks like your wire marked A is not connected to anything.  You could move it to anywhere in the b rail or e16.
You need a trace cut under C7
You don't need the trace cuts at c18 and d18
Otherwise, looks good to me.
EZ
mac
I suggest to let space for a 6.8uf poly instead of the 10uf electro at the end. It sounds better... imho
mac
solarplexus
Ok it's been awhile since I tried to finish this vero, but here's a revision that I would like you to help me verify.  I think it's ok to go, but I need a fresh pair of eyes...
Here it is :
You see any errors?
DIY Poser.
ezanker
I think D should go to Tone lug 3.  On both tone and intensity, I'm not sure which lug should be 1 vs. 3 so you may need to swith these to make the pot turn in the right direction.  Just check before soldering wires to the pots.
If your jfet is a j201, the pinout is usually G-S-D as you have it oriented, NOT D-G-S.
Otherwise it looks good to me.
EZ
solarplexus
you mean Q1 is backwards?   The JFET is suposed to be a 2N5457
DIY Poser.
ezanker
