Blending Question
Started by Barcode80, May 13, 2007, 09:29:55 PM
Barcode80
I am building a BMP for a bass player friend of mine. i know it sounds great stock on bass, but i want him to be able to dial in some clean to ensure he has his tone shining through. as opposed to a blend knob, i want separate pots for clean and dirty volume levels. would this be as simple as wiring the clean signal to a 100k volume pot which he can use when effect is engaged to dial in clean signal? or would i have to place a buffer or something in the path before that volume?
  Split the pot wiring of the blend pots *original wiring assignments.
  Using a '2 lug' pot between *pin 1 and wiper.
  Another 2 lug pot between *pin 3 and wiper.
  OR
  Wire two regular volume pots with third pin ground assignments.
  Tie the wipers [outputs] of the pots together, treat them to the original pots wiper wiring assignment.
  But I'd take a look at a 2 ch mixer before deciding on one of those choices^, which'd be about the same thing except the signal voltage dividing [volume controls] would be getting done at before the actives input, perhaps reducing mixer type distortion.
  Someone else ?
Timebutt
Did this blending for the Big Muff work out?
Somebody I know asked me to mod his Russian Muff so that it has a blend for the clean and dirty signal, but I'm confused as how to wire this exactly? Perhaps somebody knows of a link or schematic, it would help out a lot :)
Completed Projects: Gus Smalley Booster, Modded Russian Big Muff, Orange Squeezer, BYOC Vibrato, Phase 90
Barcode80
i eventually abandoned it because i had a time frame to finish the pedal but i know everyone here seems to have had good luck using the buff n blend circuit. it's labelled well so you can wire easily.
http://www.geocities.com/jrtookmyfalseteeth/buffblnd.gif
royzic
Thanks for bringing this up again,
the circuit seems allmost "too simple"
are there any issues with it?
Barcode80
dunno, but there is a layout in my gallery which a commenter has said works, so you can try it out! just let me know if it works for you.
foxfire
i have used it with ggg muff fuzz and a 4ms.fuzz jade without any problems.
Barcode80
do you mean my layout or the circuit itself?
