Moosapotamus ADA flanger project...
Started by Pierre, June 26, 2007, 03:39:15 PM
Pierre
Hi !!
I want to build a ADA flanger clone, but I'm having some difficulties trying to make the pcb from this .gif imagehttp://moosapotamus.net/IDEAS/ADAflanger/ADAflangerBOTrev02.gif
...When reducing, some pads are too close to some traces, allmost touching...
Any ideas..? :icon_wink:
Thank you !!!
Barcode80
check the for sale section, i'm not sure if they've ordered yet or not but i believe they were organizing another mass buy of manufactured versions of the board. as for th one posted, simply use your graphics editor after shrinking and cut some lines between the traces, just enough to make sure they don't touch.
Pierre
at this moment i can't afford buying the pcb, so i dont have any other choice than do it myself...i'll keep trying with photoshop.
The one that comes easy is rev. 3 http://moosapotamus.net/IDEAS/ADAflanger/Mike%20I%20mod%20SAD1024%20ADA%20flanger%20rev3%20layout1-1.pdf
but I'm not sure if this version works as rev. 1...
Pierre
