Buff'n Blend VERO layout
Started by Toney, July 17, 2007, 06:48:54 AM
Toney
Inspired by Barcode80's use in the Red Fuzz.
You can build it into any effect...very useful!
Here... ;D
Toney
Schematic here...... http://www.geocities.com/jrtookmyfalseteeth/buffblnd.gif
This got me thinking.
I suppose a Jfet may slightly color the tone.
It should be relatively simple to adapt as a Mosfet for a more neutral tone.
GREEN FUZ
This looks useful. Could it be adapted to blend two circuits in one enclosure?
Toney
You mean as a sort-of 'warp' between two effects from one input?
GREEN FUZ
I guess Warp would describe it. Specifically, I had imagined warping/blending the outputs of an Uglyface and some other as yet unspecified Distortion/Overdrive.
Toney
Ok, It would sem tempting to just add a pot at the end, but impedence issues make it difficult..
this should do the trick  ;)
GREEN FUZ
Quote from: Toney on July 17, 2007, 09:13:16 AM
In my blissful ignorance that`s what I`d hoped for. Looks like a lot of parts for a seemingly simple function.
Quotebut impedence issues make it difficult..
Thanks for the link.
Barcode80
actually (and i think this is essentially what the splitter bend at ROG does) what you speak of merely means you need to run the outputs to a pot just like you said, but then place a buffer on the output from the wiper. splitter bend is the way to go though.
