clean octave up and down
Started by changes, July 24, 2007, 08:02:15 AM
changes
is there any schem for a clean octave up/down?
i don't want fuzz just the octave effect
CHANGES
Legitimate question, but BOY has it been asked often!
Two responses:
1) Search the forum for previous threads.
2) General consensus is that neither are easily realizable in the analog domain.  You'll always get some audible distortion simply because of how octaves are obtained.  It's just a question lof how much and how willing you are to sacrifice clarity for the goal of having something that doesn't sound distorted.  Finally, up and down use different processes.
changes
thanks for the reply Mark
I did search the forum but couldn't find a schemo for a pedal that does both
I have no problem if it is analog or digital as long as i can easily get the parts
any recommandetions?
CHANGES
SonicVI
Search around for the Pearl Octave pedal, it does one and two octaves down and one octave up.  I know I've seen the schematic on the web somewhere.
...And there is the Super-Octaver project posted on my site (http://hammer.ampage.org).
Just keep in mind that there is a world of difference between a digital harmonizer that upshifts or downshifts the *entire* signal, regardless of how many notes are involved, and an analog octaver that will only handle one note ata time in down mode (and consequently tends to force mono properties on the up mode as well if they are to be used concurrently),
All analog octaves up/down cause some notable degree of distortion.
Clean octaves require not just digital, but DSP. There is a digital and dsp forum but there have been no octave shifting designs there. I don't know of any DIY digital octave up/down.
The cleanest of the octaves up is the MOS Doubler at GEO. But that doesn't help with your octave down, and it's a single-note-at-a-time effect, like all analog octaves.
magikker
Hey R.G. The link at the top of your page http://www.geofex.com/schemata.htm to the Mos Doubler is dead (the one under new effects) .... the link futher down the page works though.
Thanks. I'll go clean that up in my next sweep of the page.
zeta55
Quote from: Mark Hammer on July 24, 2007, 10:46:23 AM
I did try that Super Octaver. It did produce somewhat clean up and down octaves as I remember. However it was some time ago and I was never pleased with the circuit. After many mods and tryouts it ended up in my "box of never completed circuits"
/Krister
Visit my site: http://www.zeta-sound.se/
changes
couldn't find the pearl schematic but the super-octaver looks good.
i think i'll give it a try
CHANGES
lowstar
hank reynolds 3rd who is a forum member here has done a unverified layout for the pearl octaver.
http://www.diystompboxes.com/smfforum/index.php?topic=52169.0
was not so hard to find, 20 sec using the search function.
and the schemo at discofreq´s site:
http://filters.muziq.be/files/schematics/pearl_oc-07.jpg
took 5 minutes to search for.
cheers,
lowstar
effects built counter: stopped counting at 100
