on/off mini switch to disable 9v battery
Started by czech-one-2, August 08, 2007, 08:23:06 AM
czech-one-2
hi, i have a ross phaser that can only be powered by a 9v battery as the dc jack is + ground.
i'd like to install a mini on/off switch [in the existing hole for the 1/8'' dc jack] to disable the battery while the pedal is connected to other pedals in the pedal board. the mini switch has three lugs and im dealing with four wires.
1] battery +
2] battery -
3]input jack +
4] board -
(the wire im calling board - is black and currently connected to the battery snap -)
i know this must be a simple procedure but i dont want to risk damaging this lush sounding phaser.
thanks for your time!
czech-one-2
thanks heyniceguy!
battery - to one of the outside switch lugs
board wire to middle switch lug
works like a charm! nuff respect!
