small bear bc108/109 question
Started by msurdin, August 11, 2007, 11:59:09 PM
msurdin
I just wanted to double check which legs are which. E,c and b.
I was thinking the tab with the leg underneith is E, then b and c?
Matt
yeah that's right. Best thing to do if you're not sure is check the datasheet they normally show the pin outs.
http://www.alldatasheet.com/view.jsp?Searchword=BC108
smallbearelec
Those are a TO-18 can. Look at the bottom with the tab on your right. Tab is the emitter, collector is horizontally opposite, base at bottom.
SD
