Sans Amp GT 2 and shielded cable
Started by rasco22862, August 08, 2007, 08:26:53 PM
rasco22862
Hi, i´m wiring the Sans Amp GT2 project. I´m putting shielded cables for the In,Out>DPDT>In Fx, Out Fx (4). The shield should be connected to ground in only one side of the cable. In the In, Out>DPDT connections, i connected the shield to the sleeves of the jacks.
But in the DPDT>In Fx, Out Fx, where i sould connect the shield?
stephanovitch
if you use the jack connector to switch on or off your stompbox, you must connect the shield to ground of your circuit for the in and the out.
Ground jack>ground circuit for the in, and ground circuit>ground jack for the out
rasco22862
Is this layout ok?
I mean, where should i connect de DPDT>PCB cables shield?
rasco22862
rasco22862
how are the connections ? should i connect the shield all together in de dpdt zone? ???
stephanovitch
That's ok if you connect all the grounds together next to the dpdt
jpm83
rasco22862
That is ok with a 3PDT, you connect the shield to the Ground of the LED connects to ground. What about in a DPDT?
rasco22862
rasco22862
rasco22862
